客户的服务器内存占用较大,造成元动系统卡顿感,主要表现是在查询报表、数据较大时出现,可能是由于数据库死锁造成的。查询死锁的方法如下:use master
go
declare @spid int,@bl int
DECLARE s_cur CURSOR FOR
select  0 ,blocked
from (select * from sysprocesses where  blocked>0 ) a
where not exists(select * from (select * from sysprocesses where  blocked>0 ) b
where a.blocked=spid)
union select spid,blocked from sysprocesses where  blocked>0
OPEN s_cur
FETCH NEXT FROM s_cur INTO @spid,@bl
WHILE @@FETCH_STATUS = 0
begin
if @spid =0
            select '引起数据库死锁的是: '+ CAST(@bl AS VARCHAR(10)) + '进程号,其执行的SQL语法如下'
else
            select '进程号SPID:'+ CAST(@spid AS VARCHAR(10))+ '被' + '进程号SPID:'+ CAST(@bl AS VARCHAR(10)) +'阻塞,其当前进程执行的SQL语法如下'
DBCC INPUTBUFFER (@bl )
end
CLOSE s_cur
DEALLOCATE s_cur
go
查询到死锁后,杀死锁就不会卡了
