首页 » S4产品FAQ » 客户服务 » 常见问题问答 » Sqlserver 错误2812:未能找到存储过程sp_password
zw - 2015/1/21 17:38:25
今天在在修改sql密码时提示 错误2812:未能找到存储过程\'sp_password\' ,密码修改不了存储过程不见了,后来问了原理是管理员把sp_password存储过程删除了
原因分析
未能找到存储过程'sp_password' 就是sqlserver中的sp_password存储过程不见了,我们只要重新创建一个sp_password存储过程即可解决。
重建 sp_passsword 存储过程 代码(用WINDOWS身份验证登陆到SQL SERVER的查询工具。
复制--粘贴--执行就OK拉)运行
代码如下:
-- SQL代码开始
sp_configure 'allow updates', 1
RECONFIGURE WITH OVERRIDE
go
use master
go
if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[sp_password]') and OBJECTPROPERTY(id, N'IsProcedure') = 1)
drop procedure [dbo].[sp_password]
go
create procedure sp_password
    @old sysname = NULL,        -- the old (current) password
    @new sysname,               -- the new password
    @loginame sysname = NULL    -- user to change password on
as
    -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES --
set nocount on
    declare @self int
    select @self = CASE WHEN @loginame is null THEN 1 ELSE 2 END
    -- RESOLVE LOGIN NAME
    if @loginame is null
        select @loginame = suser_sname()
    -- CHECK PERMISSIONS (SecurityAdmin per Richard Waymire) --
IF (not is_srvrolemember('securityadmin') = 1)
        AND not @self = 1
begin
    dbcc auditevent (107, @self, 0, @loginame, NULL, NULL, NULL)
    raiserror(15210,-1,-1)
    return (1)
end
ELSE
begin
    dbcc auditevent (107, @self, 1, @loginame, NULL, NULL, NULL)
end
    -- DISALLOW USER TRANSACTION --
set implicit_transactions off
IF (@@trancount > 0)
begin
  raiserror(15002,-1,-1,'sp_password')
  return (1)
end
    -- RESOLVE LOGIN NAME (disallows nt names)
    if not exists (select * from master.dbo.syslogins where
                    loginname = @loginame and isntname = 0)
begin
  raiserror(15007,-1,-1,@loginame)
  return (1)
end
-- IF non-SYSADMIN ATTEMPTING CHANGE TO SYSADMIN, REQUIRE PASSWORD (218078) --
if (@self <> 1 AND is_srvrolemember('sysadmin') = 0 AND exists
   (SELECT * FROM master.dbo.syslogins WHERE loginname = @loginame and isntname = 0
    AND sysadmin = 1) )
  SELECT @self = 1
    -- CHECK OLD PASSWORD IF NEEDED --
    if (@self = 1 or @old is not null)
        if not exists (select * from master.dbo.sysxlogins
                        where srvid IS NULL and
                     ( (@old is null and password is null) or
                              (pwdcompare(@old, password, (CASE WHEN xstatus&2048 = 2048 THEN 1 ELSE 0 END)) = 1) )   )
        begin
      raiserror(15211,-1,-1)
      return (1)
     end
    -- CHANGE THE PASSWORD --
    update master.dbo.sysxlogins
set password = convert(varbinary(256), pwdencrypt(@new)), xdate2 = getdate(), xstatus = xstatus & (~2048)
where name = @loginame and srvid IS NULL
-- UPDATE PROTECTION TIMESTAMP FOR MASTER DB, TO INDICATE SYSLOGINS CHANGE --
exec('use master grant all to null')
    -- FINALIZATION: RETURN SUCCESS/FAILURE --
if @@error <> 0
        return (1)
    raiserror(15478,-1,-1)
return  (0) -- sp_password
GO
sp_configure 'allow updates', 0
-- SQL代码结束
如果还是不行我们可下面代码直接在在查询分析器运行一下就行了,代码如下:
use master
go
create procedure sp_dropextendedproc --- 1996/08/30 20:13
@functname nvarchar(517) -- name of function
as
**  If we're in a transaction, disallow the dropping of the
**  extended stored procedure.
if @@trancount > 0
begin
  raiserror(15002,-1,-1,'sp_dropextendedproc')
  return (1)
end
** Drop the extended procedure mapping.
dbcc dropextendedproc( @functname )
return (0) -- sp_dropextendedproc
查看完整版本: Sqlserver 错误2812:未能找到存储过程sp_password
